发表于 2018-8-23 17:07:01
显示全部楼层
ZigBee 3.0 IP Compatibility
ZigBee 3.0 is also fully IP compatible. ZigBee devices, just like Wi-Fi devices, are usually connected to
the internet via a router, gateway or set-top box, and as such can be immediately controlled by any other device that is connected to the internet -- from PC, to tablet or smartphone app, and from any place in the world. Because ZigBee is fully Wi-Fi and IP compatible, there is no need to have a ZigBee chip in the phone itself in order to find and control ZigBee connected smart home and IoT devices. It all happens through any web-connected hub (ZigBee enabled router, set-top box, gateway), which means that connected PCs and smartphones (via Wi-Fi or cellular) can function as dashboards, as they can find and communicate with any ZigBee devices without a problem.
ZigBee 3.0 IP兼容性
ZigBee 3.0也是完全兼容IP的。ZigBee设备,就像Wi-Fi设备一样,通常通过路由器、网关或机顶盒连接到互联网,因此可以马上由连接到互联网的任何其他设备——PC、平板电脑或智能手机应用程序来控制,可以来自于世界任何地方。因为ZigBee和Wi-Fi是IP完全兼容的,所以不需要在手机本身中安装ZigBee芯片,来发现和控制ZigBee连接的其他智能家庭和物联网设备。这一切都通过任何网络连接集线器(ZigBee的路由器、机顶盒、网关)发生,这意味着连接的PC和智能手机(通过Wi-Fi或蜂窝)可以充当仪表板,因为它们可以轻松地找到任何ZigBee设备并与之进行通信。 |
