For FEM, Mom, Option, Etc.
Agilent ADS 2013.06 License file
1- Replace the files with original ones:
I)-ADS root folder
II)- C:\Program Files\Agilent\EEsof_License_Tools\bin
2-Restarting is needed if below procedures did not work.
3- Copy the license file to somewhere and change the "FFFFFFFFFFFFFFFF" inside it with your favorite Mac Address.
If below procedures did not work, just disable all of your network adapters except the one that you are using its address inside the license file.
4- No need to define ADS_LICENSE_FILE variable. If you have previously defined it, just remove it. You need to use a license server in this version.
5- Run 'aglmmgr.exe' inside "C:\Program Files\Agilent\EEsof_License_Tools\bin" folder and add the license file by using buttons and just follow the wizard.
6-If you'd succeed to patch it and the license file was detected, a window with a green mark will inform you that your license is valid and you're ready to run. At the end, just look at the license availability inside 'aglmmgr.exe'. If it shows "100", it means that you have done well but if it shows "0", it means you can not run ADS.
7- Once again, If you had any problem, just reboot your system and try again.
8, can run FEm
Just for academic purposes, commercial use is strongly prohibited.
好消息!!!
ADS2013.06 已经可以完整使用了 (Momentum、fem,Option)都能使用..河蟹文件.
关键只在--所有该做的都做了之后......确定 C:\Agilent\ADS2013_06\Momentum\10.24 <-这个子夹名称一定要是 10.24
如果你在河蟹时,是被改成 ......Momentum\10.20 !? 那就rename 成......Momentum\10.24 即可.
常见问题;
1-. 不需要改时间区域
2-. 装不好,卸载之后提示无法安装??
把 C:\Program Files (x86)\Zero G Registry\.com.zerog.registry.xml
及 C:\Program Files\Zero G Registry\.com.zerog.registry.xml
这两个文件砍了 ***Zero G Registry是个隐藏属性子夹!
ADS2013.06_FEM_crack1.part01.rar
4.25 MB, 下载次数: 1425, 下载积分: 威望 1 , 金钱 -1
ADS2013.06_FEM_crack1.part02.rar
4.25 MB, 下载次数: 1335, 下载积分: 威望 1 , 金钱 -1
ADS2013.06_FEM_crack1.part03.rar
4.25 MB, 下载次数: 1290, 下载积分: 威望 1 , 金钱 -1
ADS2013.06_FEM_crack1.part04.rar
4.25 MB, 下载次数: 1299, 下载积分: 威望 1 , 金钱 -1
ADS2013.06_FEM_crack1.part05.rar
4.25 MB, 下载次数: 1049, 下载积分: 威望 1 , 金钱 -1
