查看: 13498|回复: 20
Qorvo 在线设计小工具
金牌会员
Rank: 6Rank: 6
发表于 2016-6-8 09:06:10 | 显示全部楼层 |阅读模式
Bandpass Filter Response Calculator
bandpass-filter.png View and analyze Butterworth and Chebyshev filter performance using frequency inputs.
Cascade Calculator
cascade.png Analyze system performance including small-signal gain, noise figure and one-dB compression point.
dBm-Volts-Watts Conversion
dbm-volts-watts.png See the relationship between power in dBm, Watts and RMS Voltage. This is relevant for many power applications.
Noise Figure & Noise Temperature Calculator
noise-figure.png Calculate the noise figure and noise temperature of an RF system.
Pad Attenuator (Pi & Tee) Calculator
pad-attenuator.png Obtain the resistor values of a Pi and Tee attenuator based on impedance and attenuation inputs.
RF Impedance Matching Calculator
rf-matching.png Calculate capacitance and inductance of an L-Match network by entering the R load and inputs as well as the center frequency range. This type of calculator is useful in matching one amplifier output to the input of a following stage.
Trace Width Calculator
trace-width (1).png Calculate trace width values based using the IPC-2221 charts by providing inputs such as current thickness and temperature values.
VSWR / Return Loss Conversion
vswr.png See the relationship between VSWR and return loss. The VSWR value range from 1.01:1 to 3.5:1.
更多关于Qorvo 在线小工具,请进入Qorvo 查看:http://www.qorvo.com/design-tools
中级会员
Rank: 3Rank: 3
发表于 2016-7-26 16:22:02 | 显示全部楼层
过来灌灌水哈
新手上路
Rank: 1
发表于 2016-8-10 14:19:36 | 显示全部楼层
看看看在吗
注册会员
Rank: 2
发表于 2016-8-13 15:32:15 | 显示全部楼层
这是手机上用的吗?有没有PC版的
新手上路
Rank: 1
发表于 2016-8-24 13:42:15 | 显示全部楼层
下来看看
注册会员
Rank: 2
发表于 2016-9-8 21:24:30 | 显示全部楼层
试试看
新手上路
Rank: 1
发表于 2016-10-18 10:57:46 | 显示全部楼层
收下,作参考
注册会员
Rank: 2
发表于 2016-11-8 22:24:44 | 显示全部楼层
看到这种小东西就想都下载了用用
注册会员
Rank: 2
发表于 2016-11-11 10:05:33 | 显示全部楼层
小工具很好用
注册会员
Rank: 2
发表于 2017-2-10 18:42:53 | 显示全部楼层
謝謝分享
Archiver|手机版|小黑屋|RF技术社区
GMT+8, 2024-4-24 16:17 , Processed in 0.088576 second(s), 13 queries , MemCache On.
