查看: 1538|回复: 1
射频技术入门之:天线基础
高级会员
Rank: 4
发表于 2014-9-22 17:21:16 | 显示全部楼层 |阅读模式
非常经典的英文天线基础入门教程。
Antenna Basics
Introduction
Antennas are a very important component of communication systems. By definition, an antenna is a device used to transform an RF signal, traveling on a conductor, into an electromagnetic wave in free space. Antennas demonstrate a property known as reciprocity, which means that an antenna will maintain the same characteristics regardless if it is transmitting or receiving. Most antennas are resonant devices, which operate efficiently over a relatively narrow frequency band. An antenna must be tuned to the same frequency band of the radio system to which it is connected, otherwise the reception and the transmission will be impaired. When a signal is fed into an antenna, the antenna will emit radiation distributed in space in a certain way. A graphical representation of the relative distribution of the radiated power in space is called a radiation pattern.
考验大家英文功底的时候到了。
射频技术入门之:天线基础.pdf
3.24 MB, 下载次数: 148, 下载积分: 威望 1 , 金钱 -1
中级会员
Rank: 3Rank: 3
发表于 2015-1-18 23:03:37 | 显示全部楼层
不错,赞一个
Archiver|手机版|小黑屋|RF技术社区
GMT+8, 2024-5-7 13:55 , Processed in 0.090179 second(s), 11 queries , MemCache On.
